Editing Discounts
  1. Log in to the EMS app, and then click Edit Discount.
  2. Search for the discount, and then double-click it.
  3. If necessary, update the name, click Next, and then specify if you want to apply the change to the discount at every location.
  4. Select the locations and revenue centers to receive the updated discount.
  5. If necessary, select a revenue center, and then update its POS workstation settings.
  6. On the Publish Data page, specify when the changes take effect.
    To schedule the changes to take effect at a later time, select Create a new batch to publish, and then specify the date and time.
    To add the changes to a batch, select Add to an existing batch, and then select the batch from the table.
  7. Click Publish.
