Editing Prices
  1. Log in to the EMS app, click Modify Prices, and then filter or search for the item.
  2. Select the item, and then click Next.
    Only the locations and revenue centers that have the menu item appear on the Selected Locations page.
  3. Select the locations to receive the price changes, and then click Next.
  4. To make changes to one location and Revenue Center at a time, use the location and revenue center drop-down lists to filter your selections. Otherwise, the app applies the changes to all similar items in all locations and revenue centers at once.
  5. Change the prices.
    To change all menu items to the same price, enter the new price in the Set Prices field, and then click Set.
    To change the prices of all menu items by the same dollar amount, enter the amount in the Adjust By field, select Units from the drop-down list, and then click Set.
    To change the prices of all menu items by the same percentage amount, enter the amount in the Adjust By field, select Percent from the drop-down list, and then click Set. To round the percentage, select the round value from the Round By drop-down list.
    After you click Set, the Diff column shows the difference between the old and new price and
  6. To save changes for menu items and apply them in a batch at a later time, clear the Change Active check box for the menu items, and then click Next.
  7. On the Publish Data page, specify when the changes take effect.
    To schedule the changes to take effect at a later time, select Create a new batch to publish, and then specify the date and time.
    To add the changes to a batch, select Add to an existing batch, and then select the batch from the table.
  8. Click Publish.
