| Field | Description |
Override Day Part |
Select the day part you want to override. |
Location |
Select the location for the override. |
Revenue Center |
Select the revenue center for the override. |
Beginning Fixed Period |
Select the start time for the day part. The system administrator can configure the interval for the drop-down list. |
Ending Fixed Period |
Enter the end time for the day part while making sure that the time does not overlap with the start time. |
Report Display Order |
Enter the order in which reports list the day part. |
Apply To |
Select or deselect the days of week for which this day part applies. You can click Clear Days to deselect all days. |
Parent topic: Financial Calendars and Day Parts
