Portlet
Select the portlet.
Side Menu Title
Select the side menu in which the portlet appears on the Reporting and Analytics home page.
Sort Order
Specify the order in which the portlet appears in the side menu. For example, if you type 1, the portlet is the first portlet listed in the side menu.
Hide
Hides the portlet in the side menu.
Enable myPage
Enables users to add the portlet when they customize their myPage.
Parent topic: Roles, Permissions, and Users
Scripting on this page enhances content navigation, but does not change the content in any way.
