| Field | Description |
Name |
Type a unique name for the portlet. For example, when creating a report portlet, type the report name that appears in the Reporting and Analytics side menu. |
Type |
Select the portlet type. For example, select Report to create a report portlet. |
URL |
Type or select the portlet URL. The portlet type you select determines the values that appear in the URL drop-down list. For example, if you select Report from the Type drop-down list, system reports appear in the URL drop-down list. |
Description |
Type a description of the portlet. |
myPage Title |
Type the title for the portlet that appears on the user myPage. |
Effective Dates |
Select a start date for the portlet. |
to |
Select an end date for the portlet. The portlet expires on the date you select. |
Parent topic: Roles, Permissions, and Users
