Configuring Analysis Report Permissions
  1. In the Reporting and Analytics side menu, click the link to go to the Role Portlets Administrator For page. If you cannot find the link, contact your system administrator.
  2. Select the user role for which you want to configure analysis reports publishing permissions, and then click Configure.
  3. Add the OBIEE Self-Service portlet, or select OBIEE Self-Service and then click Edit.
  4. Select or unselect Publish/Un-Publish Analysis, and then click Save.
