| Setting | Description |
Business Dates |
Select business dates for the report by performing one of the following:
Locations |
Select the locations for which the report returns data. |
Revenue Centers |
Select the revenue centers for which the report returns data. |
Order Types |
Select the order types for which the report returns data. |
| Option | Description |
Save |
When you select the report from the Reporting and Analytics home page side menu, the report runs with the settings you selected in step 3. For example, if you configure the Daily Operations report to search by the location Maryland, USA and then click Save, all users running the Daily Summary report generate a report for the location Maryland, USA unless they change the search settings. |
Restore defaults |
Restores the factory defaults for the report. |
Save as |
Saves the report with the settings you selected in step 3 as a custom report in Other Reports. For example, you can configure the Daily Operations report for a specific organization and save it as an alternate version of the Daily Operation report, as shown in the following image:
Set as Favorite |
Makes the report easier to access. Reporting and Analytics adds a star next to the report name and adds it to the Reports section of the home page side menu.
Set as Home Report |
You can configure your personal settings to open the report when you log in to Reporting and Analytics. Configuring User Preferences provides more information. |
Enable Auto Run |
Controls if the report runs after you click the report. If you turn off this setting, you have to click Run Report every time you want to run the report. |
Parent topic: Core Reports
