The following table provides tips on completing some of the settings:
| Setting | Description |
Logon Name |
User name for logging in to Reporting and Analytics. |
Display Name |
The name that appears on the user’s myPage. For example, enter the user’s first name. |
Role |
Select a default role for the user or select a role you created for your organization (for example, District Manager). The user inherits the system privileges associated with the role. |
Active |
Select to enable the user account. |
Org Level |
The level you select determines the level of access for the user. For example, a District Manager can access information for all the locations related to the level. To limit access to store-level information for a store manager, select the store from the drop-down list. |
Revenue Center |
If your organization is set up as a food and beverage organization only, select the revenue center to which the user belongs. |
Chain Code |
If your organization supports hotel operations and restricts access to information at the hotel chain level, select all the hotel chains to which the user belongs. |
Parent topic: Roles, Permissions, and Users
