To add a fixed-length shift, drag a time block (for example, 7 hr) to the employee row in the schedule editor.
To add a custom-length shift, place the cursor in the employee row, and then drag the cursor to define the start and end times.
To move a shift to another employee, drag the shift to the new employee.
To move all shifts from one employee to another employee, right-click the name of the current employee, select Assign To, and then select the new employee.
Drag the cursor to adjust the start time or end time.
Right-click the shift, and then click Edit.
Parent topic: Scheduling
