A placeholder is a visual indicator on a schedule that shows where you need employees to satisfy staffing requirements.
- Click the Schedule Place Holder tab.
- Click Add, or select a placeholder and then click Edit.
- Update or select resource detail information, and then click Update List:
- Select the Job Category and Job that the placeholder indicates as required.
- Enter the pay Rate for the job.
