The following table lists the supported databases and operating systems for the servers hosting the respective Enterprise Back Office databases.
Table 2-1 Database Server Compatibility and Requirements
| Component | Reporting and Analytics | Gift and Loyalty | Inventory Management |
Database |
Note: 32-bit client operating systems are no longer supported when using Oracle Database 12.2c R2 (12.2.0.x) or higher. The 32-bit database client could still be installed.
Java (Java Development Kit or Java Runtime Environment) |
The installation wizard requires a compatible Java version. See Doc ID 2330734.1 for more information on versions of the Java Development Kit (JDK) or Java Runtime Environment (JRE) tested with Reporting and Analytics. If you are installing the database server through a network connection, you do not need to install Java on the database server. |
The installation wizard requires a compatible Java version. Enterprise Back Office was tested for the following version at the time of release:
