Table 1-2 Symbols in Inventory Management
| Symbol | Description |
Magnifying glass |
The magnifying glass primarily appears in the Master Data pages. The magnifying glass is a means of searching in the current result set. It searches data that is already populated. After narrowing down your searches, you have an idea of what you are looking for. By entering the name or partial name of the record in the Name field and clicking the magnifying glass, you are taken to the first possible result that matches the entered search criteria. |
Exclamation mark |
Throughout the application, an exclamation mark might appear in some of your item lists within pages. This means something has happened to your item. When you place your mouse over the exclamation mark, reasons for showing the symbol appears. |
Alert symbol |
Whenever an alert symbol is shown, it means that there is something that needs your attention within that page. |
Parent topic: Introduction to Inventory Management
