Nutrient Catalog
You can import two types of nutrient catalogs into Inventory Management:
  • Standard Catalog: A nutrient catalog created by an agency, such as the U.S. Department of Agriculture (USDA).
  • Custom Catalog : A nutrient catalog created externally, for example, by an organization that contracted a third party to document the nutritional information for their menu offering.
For detailed information about the nutrient catalog import API, refer to Oracle Restaurants Inventory Management Nutrient Catalog Import (Doc ID DOC9084). Log in to the Support Portal and then click the link to Document 9084.
