Task Management allows you to create reminders to perform certain job tasks, such as ordering supplies from a specific vendor or generating an inventory daily variance report. Tasks created in Task Management appear in the Task Menu. You must enable the Task Manager on the General Settings tab for the Task Menu to appear.
Parent topic: Maintenance
