If you have entered any quantities incorrectly and would like to start over, you can reset the item quantities using this feature. If you created an order using Suggested Ordering, this resets the quantities to the original system calculated levels. To reset item quantities:
On the Purchase Orders page, click Reset QTY, and then click OK.
Parent topic: Ordering
