Inventory Management provides an automated method for transferring product from one location to another. Checks and balances have been built in preventing fraud from either the transferring or the receiving location.
Depending on the security settings, a manager has the ability to view stock on hand of various nearby locations, which saves numerous calls to stores while looking for a product to hold them over until an upcoming delivery. It also gives regional and corporate management the ability to view product across all locations. With this tool, you can move overstock products from location to location. Moving overstock product prevents valuable cash from being tied up in inventory and at the same time ensures fresh products in each location.
The Transfers module is only available if you are not using the Transfers To/From module. If you are using the Transfers module, you also use the Requisitions module.
