Table 25-11 Event Menu Plan Settings
| Setting | Description |
Sorting |
Select how the system sorts items in the Event Menu Plan. |
Result Set Quantity |
Enter the number of records to show in the Event Menu Plan, up to a maximum of 9,999. |
Parent topic: Settings
