Table 25-15 Language Settings
| Setting | Description |
Upload and/or import translation file |
Language |
Select a language. |
File |
Click Browse and locate the required translation file. |
Encoding |
Select the required character encoding. Select Change current user language after import to change user language to the imported language. |
Parent topic: Settings
