Table 25-13 Recipe Settings
| Setting | Description |
Show Item and Recipe number |
Select this option to show the item number and recipe number in the Recipes page. |
Default Yield Unit |
Select this option to specify the default yield unit. To view a list of units, click the field label or place the cursor in the field, and then press Enter. |
Enable Weighed Recipes |
Select this option to allow users to configure recipes to deplete by weight. |
Use Validity Dates |
Select this option to allow users to assign validity dates to recipe ingredients. |
Parent topic: Settings
