Table 26-4 Production User/Role Rights
| Sub Category | Right | Allows Users to... |
Recipes |
Recipes |
Access the Recipes page. |
Save Recipes |
Create and modify recipes. |
Manage Recipes |
Add and modify recipes. |
Manage Corporate Recipes |
Manage corporate recipes. |
IP Product creation from recipes |
Create IP Products from recipes with the Production Item button. |
Show COS of Recipes |
View the recipe Cost of Sales. |
Show Recipe History/Audit Trail |
Access the Recipe History or the Audit Trail (if enabled). |
Recipe - Allow editing manual nutrients |
Enter nutrients manually into the recipe. |
Edit Recipe Nutrient Status |
Edit the recipe nutrient status. |
Recipe Versions |
Recipe Versions |
Read-only access to Recipe Versions. |
Save Recipe Versions |
Create and update Recipe Versions. |
Update Recipe with Recipe Version |
Replace Recipe with Recipe Version. |
Search Recipe Components |
Search for Recipe Components |
Access the Search Recipe Components feature. |
Replace Items |
Replace items in the Search Recipe Components page. |
Menu Modeling |
Menu Modeling |
Access the Menu Modeling page. |
Update Recipes |
Edit/save recipes changes. |
Event Menu Planning |
Access the Event Menu Planning page. |
Save Event Menu Plan |
Save event menu plans. |
Add/Delete Items to an Event Menu Plan Document |
Add/delete items to event menu plans. |
Preparation Types |
Save Preparation Types |
Set up new preparation types and change existing preparation types. |
Nutrients |
Nutrient Groups |
Access the Nutrient Groups page. |
Nutrients |
Access the Nutrients module. |
Import Nutrient Catalog |
Access the Nutrient Catalog page and gives the ability to import/update a catalog. |
Delete Nutrient Catalog |
Delete an imported nutrient catalog. |
Additive Groups |
Access the Additive Groups page. |
Additive Management |
Access the Additive Management page. |
Menu Item Linking |
Menu Item Linking |
Access the Menu Item Linking page and to edit Linking. This right also enables the Linking tab in the Recipes module. |
Production |
Production |
Access the Production page. |
Change Cost Center from List in Productions |
Change the cost center in a Production from a list. |
Preparation and Thaw Pull Reporting |
Access Preparation and Thaw Pull reporting. |
POS Systems |
Read/Book POS Revenue |
Access the Read/Book POS Revenue module. |
Manage POS Revenue |
Access the Manage POS Revenue module. |
POS Device |
Access the POS Device module. |
Yield Management |
Yield Containers |
View, add, and modify yield containers. |
Yield Management |
Access the Yield Management page. |
Add/Delete Item(s) from Yield Document |
Add/edit a yield document. |
Parent topic: User/Role Rights
