Table 26-7 System User/Role Rights
| Sub Category | Right | Description |
System Functions |
Users |
Create and modify users. Users with this privilege can change passwords and rights of other users. |
Roles |
Create and modify user Roles. |
Configurations |
Access to the Configuration page. Only the system administrator needs this right. |
Document Numbers |
Access to the Document Numbers page. Only the system administrator needs this right. |
Database Update |
Access to Database Update. Only the system administrator needs this right. |
Settings |
Access to the Settings page. |
List Management |
List Management |
Access to the List Management page. |
Purchasing Lists |
Create and modify ordering/receiving lists in the List Management page when using the Save as List option in other pages. |
Inventory Lists |
Create and modify Inventory lists. |
Issue Request/Transfer Lists |
Create and modify Issue Request/Transfer lists. |
Waste Lists |
Create and modify Waste lists. |
Production Lists |
Create and modify Production lists. |
Event Menu Plan Lists |
Create and modify Event Menu Plan lists. |
Add Items to Order/Receipt created from List |
Add items to an Order or Receipt created from a list. |
Add Items to Wastes created from List |
Add items to Waste created from a list. |
Add Items to Inventory created from List |
Add items to an Inventory created from a list. |
Add Items to Production created from List |
Add items to a Production created from a list. |
Add Items to Yield created from List |
Add items to a Yield created from a list. |
Add Items to Order Request created from List |
Add items to an Order Request created from a list. |
Add Items to Master Order List |
Add items to a Master Order List. |
Approve Master Order List |
Set the status of a Master Order List to approved. |
Finish Master Order List |
Set the status of a Master Order List to finished. |
Create/Modify Locked Lists |
Create and modify locked lists. |
Mandatory Visibility Assignment with Corporate List |
Set the corporate list visibility assignment to a status of mandatory. |
Use Cost Center Relationships in List Management |
Create, edit, and save requisition and transfer lists in List Management for cost centers that are not assigned to them in their C/S Filter. |
Scheduler Functions |
Scheduler |
Create and modify Scheduler jobs. |
Others |
Cannot Backdate Receipt |
Prevents users from adding a receipt for a past date. |
Cannot Backdate Return to Vendor |
Prevents users from adding a return to vendor for a past date. |
Cannot Backdate Inventory Count |
Prevents users from adding an inventory count for a past date. |
Cannot Backdate Invoice |
Prevents users from adding an invoice for a past date. |
Cannot Backdate Waste |
Prevents users from adding a waste for a past date. |
Cannot Backdate Yield |
Prevents users from adding a yield for a past date. |
Cannot Backdate Production |
Prevents users from adding a production for a past date. |
Cannot Backdate Issue Request/Transfer |
Prevents users from adding an issue request/transfer for a past date. |
Cannot Backdate Order |
Prevents users from adding an order for a past date. |
Show Prices |
Can view prices. |
General Functions |
Booking in last Period allowed |
Book items received and transfers in the last period. |
Manage global Visibility Criteria |
Manage the global visibility criteria (assigning cost centers to lists and recipes). |
Disable Auto Run |
Turns off the generation of a result set in all pages (except the Edit Job page) so users can select the filters before refreshing the page. |
Task Management |
Task Management |
Access the Task Management page. |
Save Task |
Create and modify tasks. |
Task Menu |
Change Status |
Cancel tasks from the task menu. |
Related Topics
Parent topic: User/Role Rights
