You can add inventory items to a count cycle template in three ways: by list, by item group, and by item.
Click Maintenance, and then click Count Cycles.
Click Refresh to view existing count cycles, click a Count Cycle, and then click Assign Inventory Items in the Assign Items column adjacent to the relevant count cycle template.
To add a list, from the Lists tab, select the lists to add, and then click Assign.
To add an item group, from the Item Groups tab, select the item groups to add, and then click Assign.
To add individual items:
From the Items tab, click Add Item(s).
In the Add Item dialog box, use the filters to streamline your search, select the items to add, and then click OK.
Repeat Step 5-b to add more items, and then once complete, click Close to exit the dialog box.
