The Nutrients tab maintains the nutrients that the organization wants to show in an item’s nutrient information.
Catalog Field: Enter or select the nutrient.
Nutrient Group: Enter or select the nutrient group.
Nutrient: Enter the name to use to identify the nutrient throughout the system. This field supports up to 25 characters.
Abbreviation: Enter the alternate name to use for the nutrient in areas where display space is a limited. This fields supports up to 8 characters.
The Unit and Accuracy fields are auto-populated based on your selections.
Parent topic: Settings
