Click Maintenance, and then click Cost Center Areas.
Select a Cost Center, select Transfer From, and then click Add Cost Centers.
For each cost center that can be queried with a request, select a Cost Center, and then select the appropriate options:
With Sub Cost Centers: Select this option to allow all cost centers below the selected cost center to have the ability to transfer items to the default cost center.
Full Link: Select this option to allow the selected cost center to have the ability to transfer items to the Transfer To cost center. For example, you want cost center A to have the ability to receive items from cost center B and give cost center B the ability to transfer items to cost center A.
