Copying Transfer and Request Settings to Another Cost Center
You can copy the transfer or request settings from one cost center to another cost center. This feature is only available for one mode at a time.
Click Maintenance, and then click Cost Center Areas.
Click Copy To..., select the cost centers or stores from the Copy To Cost Center(s) dialog box to which to apply the transfer from/to settings of the existing store, and then click OK.
