Setting a Unit as the Default Store Unit
Using the Manage Store module, you can change the default store unit for selected items. Oracle Restaurants recommends setting up each item with a store unit if no global store unit is assigned at the item group level. All reports and modules use base units when a store unit is not available.
  1. Click Store, and then click Manage Store.
  2. Search for and select the item, and then click Manage Units.
  3. In the Included pane, select the unit you want to make the default unit for the item, click Store Unit, and then click OK to confirm.
    The default unit shows in green font.
  4. Click OK to close the Manage Unit dialog box, and then click Refresh to show the default unit changed for the selected item on the Manage Store Overview page.
