The Additives tab on the Item Detail page enables you to assign additives to an item by copying additives from an existing item.
- Click Master Data, click Items, and then locate and select an additive.
- Click the Additives tab, and then click Copy Additive Assignments from Existing Item.
- (Optional) In the Copy Additive Assignments dialog box, click Item Group, select an item group from the list, and then click OK.
- In the Copy Additive Assignments dialog box, enter the item name in the Item field, select the item from the list, and then click OK.
