Type: Select the item type as either COS Item or Expense. The type designates the item group for which you can assign this item. Once the item is saved, you cannot change its type. However, you can delete and re-add the item as long as it has not been designated as a child record elsewhere.
(Optional) Item No.: Enter the internal item number. This number is not used as an external number on, for example, order forms. If you have item numbers specific to certain vendors, you can enter them in the Vendor Purchase Catalog.
Item Group: Select the appropriate item groups based on item type selection.
Base Unit: Enter the base unit for the items. Once the item is saved, you cannot change its base unit. This unit serves is the base of any unit used for this item in orders, transfers, inventory counts, and recipes. If you assign an incorrect base unit, delete and re-add the item with the correct base unit.
(Optional) Purchase Tax: Select the tax for the item when purchased.
(Optional) Use only on stock: Select this option to prevent a vendor purchase item from being created with the same item name.
Store Unit: Enter the main unit used by the store for inventory counts and reporting.
(Optional) Ignore Item in Inventory: Select this option to prevent the item from appearing in any inventory count (for example, Period Close Count: the item is not shown, but it is booked with the closing method), even if the item is assigned.
(Optional) Exclude from Critical Counts: Select this option to prevent the item from being included in critical counts.
(Optional) Count as Recipe: If this option is enabled, the item is also a recipe that is being counted as an item.
(Optional) Shipment Item: Select this option to account for the item in shipment adjustments.
(Optional) Cost Item: Select this option if the item incurs a split of the costs when an adjustment, such as shipping costs, is included in an invoice.
(Optional) Use as Base Item in Automatic Yield: Select this option to use the item as a base item for automatic yield containers. A new automatic yield list type is added to List Management. See Yield Management for more details.
(Optional) Deposit Item: Select this option if the item is a deposit item.
Price Behavior: Select the price behavior:
Dynamic Price: Select this option if users can change the item price at anytime based on the user rights.
Fixed Proposal Price: Select this option if users can only change the price in Receiving, not in Ordering based on the user rights.
Fixed Price: Select this option if the price cannot be changed anywhere.
(Optional) Last Purchase Price: Enter the most recent item purchase price.
(Optional) Sales Price: Enter the sales price the cost center uses for transfers.
(Optional) Weight Factor: Based on the base unit, enter how much the product weighs.
(Optional) Item Code: Enter the item code. This is similar to an item number. It is used to link the item to bar codes.
(Optional) Use Volume: Enter the item volume. This field is important for businesses with limited storage space.
(Optional) Gain/Loss: If the item has a gain or loss percentage associated with it, select the appropriate option and enter the percentage.
No Inventory Variances (Theo is ACT): Select this option if you do not want any variances to register for this item. This option actualizes theoreticals in inventory counts. This feature is for items that have variances and never produce depletions (for example, Ketchup packets, since there is no control over how many ketchup packets one customer takes).
Uploading Recipe Images provides more information on uploading images to the system.
Note that this option works in conjunction with the HACCP settings configured in the Cost Centers module. Take heed in enabling options only as necessary.
None: When an item is created, this is the default method assigned.
Nutrient Catalog: Select this option to link the item to an item from an imported nutrient catalog.
Manual: Select this option to enter nutrition information.
Nonconsumable: Select this option for non-food and non-drink items, that is, cleaning supplies, paper goods, and so on.
