There are many printing options available for recipes, as every organization has different needs for their cooks.
Click Production, and then click Recipes.
Use the filters to narrow your search, click the Recipe Name to open it, and then click the Print icon.
A PDF of the recipe opens in a new browser window.
Click Print on the new browser window, enter the Cost Center, select the report you want to print from the List of Reports drop-down list, and then click OK.
The report you chose opens in a new browser window.
Click the File tab on the browser window that shows the report, and then select Print.
