| Select... | To Issue Points Based On... | And Then Configure... | |
Per visit |
When a guest visits a store. |
Per check value |
The value of the guest check. |
Number of selected items |
The number of selected items purchased. |
Enter the number of points to be issued per selected item purchased in Point Factor. |
Value of selected items |
The value of the selected items purchased. |
Enter the number of points to be issued per dollar spent on selected items in Point Factor. |
Number of unique selected items |
The number of unique selected items purchased. |
Enter the number of points to be issued per each different item purchased from a predefined set in Point Factor. |
If any selected item on check |
When a guest purchases any of a group of selected items. |
Enter the number of points to be issued if an item rule is met in Point Factor. |
New items this period |
When a guest purchases an item for the first time in a given time period. |
Enter the number of points to be issued if a new item is purchased within a given time period in Point Factor. |
Additional points if selected |
If the transaction includes a selected item, issues an additional amount of points entered. This method can also be used to award points based on repeat visitation using the Number of Days From First Trans field if the transaction includes a selected item. |
Use multiplier if selected |
If the transaction includes a selected item, applies a point multiplier. |
Time rule Only |
Transactions within a designated time frame. |
Enter the number of points to be issued if a time rule is met in Point Factor. |
Additional points by visit |
Additional points per visit for each transaction. |
Use multiplier if threshold exceeded |
If the transaction exceeds the configured threshold, applies a point multiplier. |
Per check value if any selected… |
The value of the guest check if the purchase contains any of a group of selected items. |
Enter the number of points to be issued per dollar in Point Factor. |
Per defined check value |
Increments spent. |
Enter the number of points to be issued per set number of dollars in Per Defined Value. |
Enter the maximum number of points that can be issued in a transaction in Max Points Per Trans.
Enter the maximum number of transactions that can be made in a single day part in Max Trans Per Day Part.
Enter the maximum number of transactions that can be made in a single day in Max Trans Per Day.
Enter the maximum number of transactions that can be made in a single week in Max Trans Per Week. Select the day that each week starts in Max Trans Start of Week.
Parent topic: Loyalty Rule Configuration Reference
