In 20.1 and higher, navigate to the Gift and Loyalty portlet.
Click iCare, click iCare GPL, click Guest Consent Configuration, and then click Enabled.
Select the consent options you want to enable and enter the consent statement that will appear for the guest. For example, I consent to have my transaction data used by this company.
Click Enable Privacy Documentation to share your organization's privacy documentation.
If you enable marketing consent, then at least one contact rule must appear on the customer registration form:
Click iCare, click iCare GPL, and then click Customer Fields Display.
For one or more of the contact rules fields, select the column and row for the field under Position, and select whether the field is optional or required under Type.
