For example, you can assign a zero percentage to users who should not have the ability to edit a forecast. If you assign a percentage of 5%, the user can edit the forecast above and below the generated value by 5%. Leaving the field blank allows the user role the ability to edit a generated forecast between -100% to +1000%.
