The layout configuration can be changed in the labelprint.default.ini file located in the Mobile Solution Web Service in thePOSLayouts folder. This is also where you will need to configure the label size. You must also change the file name from labelprint.default.ini to labelprint.ini. If this file is changed, you must click the Reload Layout Defaults button to refresh the label layout. Please contact your Oracle sales manager if changes are required. You may also see labelprint.ini. This file is used for Reload Layout Defaults.
