SIP Duplicate SDP Suppression Configuration
To enable duplicate SDP suppression for SIP sessions:
In Superuser mode, type configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter.
ORACLE(configure)# session-router ORACLE(session-router)#
Type
sip-config and press Enter.
ORACLE(session-router)# sip-config ORACLE(sip-config)#
If you are adding support for this feature to a pre-existing configuration, then you must select (using the ACLI select command) the configuration that you want to edit.
options—Set the options parameter by typing options, a Space, and then the option name
strip-dup-sdp. Then press Enter.
ORACLE(sip-config)# options +strip-dup-sdp
If you type the option without the plus sign, you will overwrite any previously configured options. In order to append the new options to this configuration’s options list, you must prepend the new option with a plus sign as shown in the previous example.
