SIP Registration Local Expiration Configuration
You can configure this feature either for the global SIP configuration, or for an individual SIP interface.
To configure SIP registration local expiration for the global SIP configuration:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal ORACLE(configure)#
Type
session-router and press Enter.
ORACLE(configure)# session-router ORACLE(session-router)#
Type
sip-config
and press Enter. If you are editing an existing configuration, select the configuration so you can enable this feature.
ORACLE(session-router)# sip-config ORACLE(sip-config)#
options—Set the options parameter by typing
options, a Space, the option name
reg-local-expires with a plus sign in front of it, and then press Enter.
ORACLE(sip-config)# options +reg-local-expires
If you type options and then the option value for either of these entries without the plus sign, you will overwrite any previously configured options. In order to append the new option to this configuration’s options list, you must prepend the new option with a plus sign as shown in the previous example.
Save and activate your configuration.
To configure SIP registration local expiration for an individual SIP interface:
Type
Type
sip-interface
and press Enter. If you are editing an existing configuration, select the one on which you want to enable this feature.
ORACLE(session-router)# sip-interface ORACLE(sip-interface)#
ORACLE(sip-interface)# options +reg-local-expires
- Save and activate your configuration.
