PreviousNextJavaScript must be enabled to correctly display this content
Configuring Universal Call Identifier Options
The SPL options must be configured on the ingress session-agent, realm-config, or sip-interface. If you update the values of the SPL options for the Universal Call Identifier SPL, you must perform a save and activate in order for the new option to take effect.
To configure the SPL options:
In Superuser mode, type configure terminal and press Enter.
Type spl-options +UCID-App-ID=”<value>” where <value> is the additional header information to store and press Enter. The default behavior stores only the Request-URI and realm-id.
