Media Release Configuration
To configure media release across network interfaces:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
media-manager and press Enter to access the media-level configuration elements.
ORACLE(configure)# media-manager ORACLE(media-manager)#
Type
realm-config and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(media-manager)# realm-config ORACLE(realm-config)#
Select the realm where you want to apply this feature.
ORACLE(realm-config)# select identifier: 1: Acme_Realm <none> 0.0.0.0 2: H323REALM <none> 0.0.0.0 selection:1 ORACLE(realm-config)#
mm-in-system—Set this parameter to
enabled to manage/latch/steer media in the
Oracle® Enterprise Session Border Controller. Set this parameter to
disabled to release media in the
Setting this parameter to disabled will cause the Oracle® Enterprise Session Border Controller to NOT steer media through the system (no media flowing through this Oracle® Enterprise Session Border Controller).The default is enabled. The valid values are:
enabled | disabled
