H.323 Per-Realm CAC Configuration
This section shows you how to configure minutes-based CAC for realms and how to display minutes-based CAC data for a specific realm.
Note that setting the new monthly-minutes parameters to zero (0), or leaving it set to its default of 0, disables this feature.
To configure minutes-based CAC:
Use the ACLI show monthly-minutes command to see the following information:
- How many minutes are configured for a realm
- How many of those are still available
- How many calls have been rejected due to exceeding the limit
To view information about SIP per user CAC using the IP address mode: In either User or Superuser mode, type show monthly-minutes <realm-id>, a Space, and the IP address for which you want to view data. Then press Enter. The <realm-id> is the realm identifier for the realm identifier of the specific realm for which you want data.
ORACLE# show monthly-minutes private_realm
