Endpoint Demotion Trusted-to-Untrusted SNMP Trap
The system can generate an SNMP trap when an endpoint transitions from the trusted to the untrusted state. The trap is structured as follows.
apSysMgmtInetAddrTrustedToUntrustedDOSTrap NOTIFICATION-TYPE
OBJECTS { apSysMgmtDOSInetAddressType,
apSysMgmtDOSInetAddress,
apSysMgmtDOSRealmID,
apSysMgmtDOSFromUri,
apSysMgmtDOSReason }
STATUS current
DESCRIPTION
"This trap is generated when an IP is placed on a untrusted list from trusted list, and provides the ip address that has been demoted, the realm-id of that IP, (if available) the URI portion of the SIP From header of the message that caused the demotion."
::= { apSysMgmtDOSNotifications 5 }
The trap OID is 1.3.6.1.4.1.9148.3.2.8.0.5.
