The Acme Packet 4500 and IPv6
The Acme Packet 4500 supports IPv6. Ideally, IPv6 support would be a simple matter of configuring IP addresses of the version type you want in the configurations where you want them. While this is true for some configuration areas, in others you will need to take care with, for example, the format of your IPv6 address entries or where parameters must be configured with IP addresses of the same version type.
Note IPv6 may not apply to some configurations or to some parameters.
