Before You Configure
In order to run H.323 on your Oracle® Enterprise Session Border Controller, you need to configure the basic parameters: physical and network interfaces; global system parameters; SNMP, trap receiver, and accounting support, and any holiday information you might want to set.
You should also decide how you want to set up realms and routing (including the use of session agents and session agent groups) to support H.323 operations.
