Use the
sctp-max-burst parameter to assign a value to the SCTP protocol parameter, Max.Burst.
Allowable values are integers within the range 0 through 4294967295 that specify the maximum number of DATA chunks that will be sent at one time. In the absence of an explicitly configured integer value,
sctp-max-burst defaults to 4 (DATA chunks, the recommended default value from RFC 4960).
Use
done,
exit, and
verify-config to complete configuration of DATA burst limitations.
ORACLE(network-parameters)# doneORACLE(system)# exitORACLE(configure)# exitORACLE(configure)# exitORACLE# verify-config
Verification successful! No errors nor warnings in the configuration
ORACLE#
