PreviousNextJavaScript must be enabled to correctly display this content
Configuring Require Header Option Tag
You may change the Require: header’s option tag from the default com.acmepacket.cac to one of your own choosing. Remember that both systems’ option tags must match exactly.
To configure the Require: header’s option tag:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter to access the
session-router path.
ORACLE(configure)# session-router
Type
sip-config
and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# sip-config
Use the ACLI
select command so that you can work with the SIP configuration.
ORACLE(sip-config)# select
options—Set the options parameter by typing +options, a Space, the option name
con-cac-tag= your-new-tag, and then press Enter.
