PreviousNextJavaScript must be enabled to correctly display this content
SIP Enforcement Profile Configuration
To use the enforcement profile, you need configure it with a name and the list of SIP methods you want to designate as allowed. Then you need to configure the global SIP configuration, a SIP interface, a realm, or SIP session agent to use the set.
