Configuring ARP Flood Protection
You do not need to configure the Oracle® Enterprise Session Border Controller to enable the use of two separate ARP queues; that feature is enabled automatically.
If you want to configure the ARP queue policing rate, you can do so in the media manager configuration.
this feature is not RTC-supported, and you must reboot your Oracle® Enterprise Session Border Controller in order for your configuration changes to take effect.To set the ARP queue policing rate:
