TLSv1 Ciphers
The Oracle® Enterprise Session Border Controller (E-SBC) supports TLS v1, TLSv1.1, TLSv1.2, and SSLv3 ciphers.
The tls-profile object contains the cipher list parameter, and the tlsCipherList command displays the list of ciphers that you can specify. The E-SBC supports Suite B with the TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 and TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384 ciphers.
For encryption, the E-SBC supports: AES-128, AES-256, 3DES, DES and ARC4 (40 and 128 bit) algorithms. It also supports:
- TLS_DHE_RSA_WITH_AES_256_GCM_SHA384
- TLS_DHE_RSA_WITH_AES_256_CBC_SHA256
- TLS_RSA_WITH_AES_256_GCM_SHA384
- TLS_RSA_WITH_AES_256_CBC_SHA256
- TLS_DHE_RSA_WITH_AES_128_GCM_SHA256
- TLS_DHE_RSA_WITH_AES_128_CBC_SHA256
- TLS_RSA_WITH_AES_128_GCM_SHA256
- TLS_RSA_WITH_AES_128_CBC_SHA256
- TLS_DHE_RSA_WITH_3DES_EDE_CBC_SHA
- TLS_RSA_WITH_3DES_EDE_CBC_SHA
- TLS_RSA_WITH_NULL_SHA256
- TLS_RSA_WITH_NULL_MD5 (For debug, only.)
- TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 (For debug, only.)
- TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA384 (For debug, only.)
- ALL [default]
- NONE
