Before You Configure
The Oracle® Enterprise Session Border Controller ’s IWF requires that there be complete configurations for both SIP and for H.323. These two sets of configurations function together when the interworking is configured and enabled.
You enable the Oracle® Enterprise Session Border Controller ’s interworking capability when you set the IWF configuration’s state parameter to enabled, and all required H.323 and SIP configurations are established. This means that all of the following configurations must be established:
- A full SIP configuration, including SIP interfaces, SIP ports, SIP-NATs (if needed), and SIP features
- A full H.323 configuration, including H.323 global and H.323 interface configurations
- Local policy and local policy attributes (the IWF will not work without these configurations)
- Media profiles
- Session agents and, if needed, session agent groups
