If you are adding this feature to a pre-existing configuration, select the configuration to edit it.
options—Set the options parameter by typing options, a Space, the option name
acceptG729abFormat with a plus sign in front of it. Then press Enter.
ORACLE(h323-stack)# options +acceptG729abFormat
If you type
options and then the option value for either of these entries without the plus sign, you will overwrite any previously configured options. In order to append the new options to this configuration’s options list, you must prepend the new option with a plus sign as shown in the previous example.
