Alarms
These are the alarms for local playback. They are MAJOR in severity, and do not impact the system health score.
| Alarm | Description |
| Playback media file not found or couldn’t be loaded | Raised when a configuration is activated if the system cannot find a media file referenced configuration or if the system is unable to load the media file. This alarm clears automatically when a file is correctly referenced or when it is loaded properly. You might encounter this alarm if you have established playback configuration, but have not loaded the appropriate playback files to /code/media. |
| Playback could not be started due to capacity limit | Raised at call time when system has reached its maximum number of playbacks (100). This alarm must be cleared manually. |
| Playback could not be started due to unsupported codec | Raised at call time when there is a mismatch of codecs between those in available files and one that must be played. This alarm must be cleared manually. |
