Port 111 Configuration
To enable port 111 using Oracle® Enterprise Session Border Controller boot parameters:
In Superuser mode, type
configure terminal and press Enter
ORACLE# configure terminal
To enter the boot parameters so that you can configure them, type
bootparam and press Enter.
ORACLE(configure)# bootparam
Press Enter to scroll through the list of boot parameters until you reach the setting for flags.
To set this value correctly, you need to add the value 0x200000 to your existing flag setting in the boot parameters. In the example below, the existing flag value is 0x30008. When the value 0x200000 is added, the result is 0x230008. The result is the value that you need to set.
When you reach the flag setting, type the value representing the flags you need (0x230008 in the example below) and press Enter. Continue to press Enter to finish scrolling through the rest of the boot parameters.
'.' = clear field; '-' = go to previous field; ^D = quit boot device : wancom0 processor number : 0 host name : acmepacket8 file name : /tffs0/sd220p9.gz inet on ethernet (e) : 10.0.1.57:ffff0000 inet on backplane (b) : 0.0.0.0 host inet (h) : 10.0.1.5 gateway inet (g) : 10.0.0.1 user (u) : user ftp password (pw) : password flags (f) : 0x30008 0x230008 target name (tn) : acmesystem startup script (s) : 0 other (o) : NOTE: These changed parameters will not go into effect until reboot. Also, be aware that some boot parameters may also be changed through the PHY and Network Interface Configurations. ORACLE(configure)#
Type
exit to return to the main Superuser menu so that you can reboot your
Oracle® Enterprise Session Border Controller and apply the settings you have entered.
ORACLE(configure)# exit
Reboot your
Oracle® Enterprise Session Border Controller. Type a y and press Enter to reboot.
ORACLE# reboot ----------------------------------------- WARNING: you are about to reboot this SD! ----------------------------------------- Reboot this SD [y/n]?:y
